Tte Silicon Pipe Measurements
1 x 70mm wide by 80mm long = airbox to charger
1 x 60mm wide by 160mm long = lefthand side joint pipe going to intake
5 x 60mm wide by 100mm long = from charger to/from intercooler
1 x 50mm wide by 50mm long = bypass valve
1 x 50mm wide by 90mm long = bypass T pipe joint
  • 2 months later...
cheers mate, can't find things very easy now as only the last 5 or so posts by a member are stored in their profile....
press the name (top left hand corner)of the member, on a post
select "find members posts" from pull down menu
and all posts will be revealed :)
ahhh right. cheers mate.
didn't realise that little trick....lol
  • 1 year later...
Glad to see that this topic is coming in handy for others ;)
Jamie
Something else to put on my Santa list. My list is getting bigger all the time.
Did not want to get from TDI so this is very helpfull
Cheers Gord for the info you posted up.
  • 1 year later...
