Custom Built Induction Kit
sinclair
i would pay for one of them! like was said b4 it looks like it belongs!
I would definately swap my TDi one for it!
might send it off to be powdercoated first tho. or chrome plated.
Good effort Sinclair :)
If your man is going to make some more it could be worth considering the following improvements:
1) Make the tubing out of a material that will not absorb as much heat
2) Re-route the tubing away from the exhaust manifold
3) Make the tubes mandrel bent (if you retain metal) to prevent the internal restriction you have.
4) Don't "cut and shut" the pipe as the sharp bends cause a restriction.
5) A nice cold air scoop and box
Mark
