Modifying Rear Lenses
jason_l
im planning on cutting up my rear fog lights (i have the clear ones)and spraying the chrome part black!
just wanted to know if anyone has done this and what glue did they use to put them back together, also has anyone done it to the main rear lights?
thanks.
jason
Silicone.
Dobedo took his apart and colour coded his. B)
the rear fogs too?! :unsure:
my rear fogs came colour coded :whistling:
rear lights were cut apart and then siliconed back together
not the easiest job to get apart, as it is a case of cutting through the plastic lens,.....one little mistake and there knackered :duh:
front fogs were seperated using the heat method, then heated up again to stick back with a little extra silicone to seal up
rear lights and colour coded fogs
front fogs
UKAZN (alex) modded his rear lights a bit more than that! lol.
He removed the plexiglass cover, sprayed them matt black, only replacing the glass over the indicator/reversing lights. then using LED's had them as the brake lights etc. looked great having a 3D look to the rears and unlike all the nova's!
How about we get a "lexus light" company to make something different for us!!!
Unless you use the FEIN multi tool  :winky:
does that mean you dont need to heat them up using that steve ;)
the rears should not be attempted to be heated up !!!
use the fein tool to cut the plastic
the fronts will seperate with heat
stories are no good without pictures
cmon... get alex to stop being shy :D
i would do but i think he is worried about people copying him at the min, lol.
did look so different tho! would love a full set of LED rear lights like the E46 M3!
Will see if i can coax a photo outa him
they look good, a few more tweeks to do i think but we have talked about a few ways of getting more light out!
they realy look goof tho on the car its self, gives the rear corners a completely different feel
we still need to take a mold of the red light part and make a recessed well for each of the led's. that way after its been plastic chromed it will reflect more of the red light i think.
i've already got about 30 odd leds in there but i reckon i gonna need a whole lot more and that are a whole lot brighter. thing is i may need to find another set of rears to get the red lens bit out so i can drill new wholes for the extra leds.
