Ls 430 Transmission Cooler Arrived
The-Acre
Having worked away from home for nearly two months I've put this off, but finally got around to buying a transmission cooler to by-pass the radiator. I'll try to fit it tomorrow but won't be able to make the connections until the end of next week. Hopefully it won't be too bad a job. If anyone has any pearls of wisdom in the meantime they'd be appreciated.
My thinking is to put it fairly high up to so it faces the open bonnet grille, any thoughts?
post-32919-0-41885700-1430240402_thumb.j
That looks a decent unit, if you were closer I would have helped you fit it.
Thanks Steve, I really appreciate the gesture!
I'll post some photos etc when it's done. £66 so far for the kit + some Toyota trans fluid.
