Alrighty, i picked up a GS300 a couple of weeks ago, to use as a daily once i fix a couple issues. Im not sure if its been on the forum previously but its looking a bit rough these days. Excuse the exhausts, they will be getting replaced by standard ones soon haha.
There are a few faults with the car, ive had a search through the internet which has taken me onto US forums mostly, others have had the same issues. Any help appreciated!
-fuel light flashing constantly
-handbrake warning light on (fluid level is max)
-temp gauge at C and doesnt move
-blower only works on lowest fan setting
-i only have the grey valet key, and a seperate plip which only opens the boot, the central locking is inop
I'll be sure to check out the tech section, and ive downloaded a few pdf files which im yet to look through.
But any info on these faults would be awesome guys :)
Welcome to the club!
I hope you manage to resolve all the issues listed above leaving you to enjoy your car.
The car seems to be fixing itself haha, the temp gauge is now reading normal and the blower fan now works as it should. The fuel warning light has went off.
As other faults i had forgotten about
-The driver seatbelt does not retract
-The driver window switch does not work the other windows
-The stereo is faulty, half the display is flickering
The only thing i did was the 6min reset after replacing the Battery.
