Hi guys my 2000 REG LS 400 that has been laid up for a while is reving to 1500- 2000 revs untill i put it into gear , stick it in neutral back up , park back up .
Any ideas
Just wondering if the ECU is resetting after power was removed, drive it for a while to see if it relearns then drops the idle speed.
The idle speed will drop when put into drive as you have the drag/load of the torque convertor/transmission.
Is the idle speed correct when the engine has fully warmed up?
