Display "stuck" On Sport Mode
Bhavin Desai
I recently bought a CT200h Advance.
Originally, the display on the left side of the speedometer changed to a different format when the Mode changed between Sport, Normal and Eco. However, the Sport Mode display (showing rpm) has been "stuck" for several weeks, regardless of changing the Mode to Normal or Eco (which should display Charging, Normal, etc).
Is there a solution for this problem, which will effectively "reboot" the system so that the display works as intended?
Thanks in advance for your reply.
post-53030-0-25473100-1428251529_thumb.j
post-53030-0-39509700-1428251559_thumb.j
There is a setting where you can set the Rev counter display on all the time. Perhaps this has got set on by mistake.
You can check the settings from the steering wheel buttons.
If you need to know how let me know
Paul.
Sit in the car and press power twice to get the ignition on
Press disp until the settings menu appears. Press disp for a few seconds. The settings menus are now active.
Pressing disp once steps through the menu options. Pressing disp for a few seconds selects the highlighted menu item.
Keep pressing disp until meter is selected. Then press and hold disp
Keep pressing disp until tachometer meter is selected. Then press and hold disp.
Keep pressing disp until auto is selected. Then press and hold disp.
It should then say please wait.
Keep pressing disp until exit is selected. Then press and hold.
Again select exit.
Etc..
Hope that works
Paul
I didn't have the printed instructions but I did the procedure from memory and it worked. Now I have the automatic display switching in accordance with the current Sport/Normal/Eco mode.
Thanks for your help Paul.
