Hi guys just bought an is200 and the washer bottle leaks out water as soon as I put it in any ideas on how to change this ?
Hi have you by any chance first checked to see if the hose/pipe is actually attached to the washer bottle?or if there is a split in the piping as it may not necessarily be the bottle itself?.
No but if I put water in the jets work for a bit them water pisses out
So what makes you think its the bottle itself then?
The piping would/should go to your wiper jets and your headlight washer jets(assuming you have the headlight ones),you will probably have to take off the passenger side plastic black mudguard/wheel arch protector to see if piping has come loose.
ok cheers bud the windscreen washers work when I put water in it as by the looks of it a little it stays in the bottle but alot of it pisses out
