Hi guys,
Although my 450 is the facelift it still only has an aux socket and 12v power in the arm rest. Has anyone put a USB input onto one of these or could suggest a good media type gateway to achieve this?
Member Carl has installed a Vais MML from the States and I'm just about to do same. See this thread:
http://www.lexusownersclub.co.uk/forum/topic/97912-vais-mml-installed-in-gs450h/
As mentioned, I fitted mine a few weeks ago and it works superb.
Dead easy to fit and works just like the built in CD player.
If you need any more information on the unit or fitting or pictures I'm happy to help.
Regarding orders being from the states, my experience, stuff gets delivered quicker from the states than from the uk most of the time.
You will need to factor in the £25 import duty but other than that no problems.
Carl
As an alternative option to the VAIS, I recently installed a GROM-USB3 - working very well, invisible (just route it through the the arm-rest) and charges my Iphone on the move. Available from amazon (for about £119) and as easy to install as the VAIS.
Couple of installation videos (both for a GS300) below - second is the official one, but I found the first a bit more helpful:
