Vsc Fault On My Is250
greggory
Hello i am new at this ,today my is 250se-l had check vsc and the car wouldent go faster than 30 mph so i when to lexus and thay said it a fault with the fuel pressure something but i said you have just did this engine fuel pressure sensor under a recall, they said it was nothing to do with that, but not to sure but they said it could cost £800 for the part and about 1 hour to do a bit humpy diden't tell me the error code and this is from lexus so can any one help car is 2008 is250
Hello and welcome to the LOC.
I would find a decent independant garage with suitable diagnostic testers and ask them to pull the OBDII codes for you,OK they may charge a few quid but at least you will have something to go on.
Sounds like the car is in LHM (Limp Home Mode) but a VSC fault is normally associated with wheel sensors/ABS/Traction Control problems.
Once you get the codes come back with them.
