Hello and welcome to the LOC.
Good news is that the water pump on the 220d is driven by the fan/sepentine belt and not the cam belt so a lot easier and cheaper.
I would think a couple of hours labour ( find a decent independant to do the job)
If you want an OEM water pump grab one of these while you can.
http://www.ebay.co.uk/itm/GENUINE-OEM-LEXUS-WATER-PUMP-16100-09340/331465742760?_trksid=p2047675.c100012.m1985&_trkparms=aid%3D444000%26algo%3DSOI.DEFAULT%26ao%3D1%26asc%3D20140221143856%26meid%3Deb8f55954ba14604ad6a7b4b720e4b86%26pid%3D100012%26rk%3D5%26rkt%3D10%26sd%3D231358283518
Lexus fitted a new one on mine for around £300 (will edit when I find invoice) and it was a while you wait job. As Steve pointed out you can probably shave quite a bit of that price by going to a good independant with the part.
Are you 100%sure will be good to my car? My vin number is JTHBB262902007197
Please revisit this post and remove your VIN no. You're showing your car/ colour/ registration and now the VIN number.
Keep some things secret...you never know who may be using your info elsewhere.
