Hello Lexus lovers,
i would like to upgrade my standard high beam HB3 bulbs for 100w ones but i read they produce so much heat you can't use them with plastic lens's is this correct ? Many thanks James.
They are also not road legal,other motorists will flash you,the police may pull you and the MOT man will fail you :)
If you want to upgrade take a look at the uprated EU approved ones from the likes of Philips and Osram.
Thank you for your response. The reason for upgrading is simply they are a much brighter bulb and can shine a lot farther, i have used these bulbs in the past in other cars without any problems what so ever but obviously with glass lenses. As for HID's i'd have to do a conversion, although not a problem they are a lot more expensive. The thing is my car is fitted with HID dip beam from standard which are brilliant but as soon as you flick on to main beam you get sub standard yellow light (why didn't Lexus fit HID's all round) such a let down.
