Hi guys, is there anything I should look out for when doing this?
I'm going to be taking the calipers off checking them, as I can hear a scraping from 30 mph plus, and then painting them
Hi if you can remove the pistons and seals and clean the area between the seals this will stop future piston sticking apart from that not much else in a caliber
If the are ok and not split I did mine a few years ago still fine if not just get some new seals not to dear
