Look on the PF Jones web site they have the kit and also the pdf of the installation instructions.
The only Lexus one I've found on the net is for a LHD model, the connections look the same but can'ty guarante it. Westfalia produce the towbar for lexus and they do a wiring kit also. The Westfalia part No appears to be 335 357 300 113 but it isn't in the latest Westfalia catalogue the entry for the RX only ahows a kit for the 450H. It's a bit confusing!!!
Hi Reg.
Not sure if I can be of any help but when I purchased my RX (2013/450h) I had the Lexus dealer fit a tow bar for me.
Happy to look for the loom and take photos etc if that might help - if you can tell me where to look as I've no idea where it is!!
Matt.
Hi Matt, Thanks for your help, really struggling to get a wiring diagram, it's on passenger rear side behind Lamp unit, it's where a Green\Black cable goes from the black box into the main wiring loom it's probably taped over, But it may be to many panels to remove, Don't put yourself out to much. Thanks again Cheers Reg
