I've literally taken every part of my car apart (except the engine) lol
Everything is held by clips so just a case of pulling.. doesn't get easier...
Do you have photo of the trim that you want to remove?
Take a look at the link...may help you.
http://www.clublexus.com/forums/is-second-generation/691517-diy-headliner-removal-swap.html
There are some pics that should help you see what is going on there.
I've seen some other posts where they mention detaching the -ve cable on the Battery and waiting 2 minutes so that you don't accidentally deploy the curtain airbag in the pillar. Tread carefully and read as much as you can find. Don't route any cable over the airbag!
Yeah I was told that too!
Did a bit of research and came up with these...they are perfect, and not stupidly expensive either.
I have a link somewhere...I'll pm you at some point soon.
They take about 30/40 mins to fit and fit perfectly on my 250. I don't know if the f sport has same body profiles?
