I have a black rectangle at the bottom left corner (from sitting inside), I was wondering if anyone knew what it is? I has a cable to it.... It's around 8 by 4 cm
I will take a picture tomorrow to show you guys
Also I was wondering if anyone knew what the 2 black circles are on the dash... I'm assuming one is for the auto lights but what's the other?
Sounds like aftermarket phone kit. There was one fitted to my old IS200 that sounds exactly like that.
The two domes on the drivers side are sensors. One is indeed for your auto lights. The other is the climate control sensor
Managed to get a picture today :)
Anyone know what it is?
thanks for the reply... If you don't mind which one is which and what does the climate control actually do? Just sense temp?
post-52465-0-81997900-1422709811_thumb.j
post-52465-0-27569000-1422709823_thumb.j
Thats a tax disk holder if you ask me.
That'll be an aerial for a phone kit that's also a disc holder I have had to remove plenty when changing windscreens
If u are not using it then unstick it from screen and either snip the wire of and tuck it away ot trace it back and disconnect it
Thanks mate :)... would like to trace it back, would it be going to the head unit or else where?
That's exactly the sane as my old aftermarket phone kit. Ariel on the tax disc holder with a wire leading into glove box (where the phone kit would've been)
As for the sensors, I don't know which one is which but easy to find out. Turn headlights on auto in the day time and cover one until the lights come on. And yes the climate one senses the temp in the cabin and adjusts it accordingly depending on what temp you are asking for, that's why you have temps written on your dial
Thanks, :) sorted that one out now then will remove the kit when I get a chance... any tips?
