Just noticed this morning that my back lights on radio/heating controls are on when headlights switch is off then go out then headlight switch is turned on and lights dim on dashboard (found out they dim to reduce glare at night)
so problem is just with lights going out on radio etc, I have a issue with flashing dashboard (capacitors need sorting?) but is this a seperate issue if so ideas would be greatly received
Thanks Del
