Cctv- Parking Mode Footage
Guys
In light of the incident with my car has anyone thoughts on some decent dash cams that will facilitate some parking mode coverage? I am not sure how this would work as some inbreds could approach the car from any angle? not necessarily from the front/rear.
I came across this
https://www.joovuu.com/gb/home/206-motion-detection-car-accessory.html
would it be a good match with a black vue?
http://www.ebay.co.uk/itm/Blackvue-DR650GW-2CH-16GB-Full-HD-Front-and-Rear-Wi-Fi-GPS-In-Car-Camera-Dashcam-/261744654750?pt=LH_DefaultDomain_3&hash=item3cf132799e
cheers
I have the Blackvue 650 which came with a unit to connect it up so that it could record when parked, but also monitor the Battery voltage and shut off at a predetermined voltage so you don't end up with a flat Battery. At this time I have only plugged it into the cig lighter so parking isn't covered. The cameras are pretty small and the front one can sit behind the rear view mirror, almost unseen. Picture quality is good and the downloadable apps are easy to figure out. Pls note that the cameras have no screens so you have to view the files by putting the memory card in a PC or download them by the built in wifi to your phone or iPad. All in all, I'm happy and impressed with the end results and minimal look that doesn't resemble a bad afterthought
does the parking footage come from just the front/rear?
I have heard about the black vue attachment also.
Eric, with the Blackvue, the files are split front and rear, easily marked for which is which and identifiable for the exact date and time. They are recorded for 1 minute each and on the playback virtually seamless. You also get the vehicle speed and GPS location shown on a moving map in the file viewer.
