Driving along this morning when all of a sudden the brake light on the dash lights up when i push the brake pedal and sometimes when just driving along.
car has done 19800 miles.
have the brake pads worn down already?
any suggestions
thanks in advance
Paul
Brake warning light on a Mk1 GS300 is certainly the brake fluid level.
The level in the resevoir is very deceptive and you need to top up carefully then depress brake pedal a few times then finish topping up.
This worked for me but I did have brake sytem checked out incase there was any fluid leaks and all was ok.
Check your brake lights when it comes on.
I've been having similar bother, off-and-on with my MK1 Gs. It is down (on mine anyway) to a dodgy contact with the bulb/holder. When the light (red, with exclamation mark) comes on, it is imediately accompanied by my o/s brake lamp not coming on. I had pads replaced thinking it was similar problem.
As soon as I remove rear lens to check, bulb comes on and warning light goes out. I've tried electronic contact cleaner, emery paper around bulb contacts, all sorts. Damn thing comes on first time I drive off and touch the brakes!
Haven't tried replacing bulb yet, but that is next on agenda at weekend.
regards,
Steve J
regards,
Steve J
Same problem with mine but it's intermittent, so probably a dodgy bulb but keep forgetting to change it. Plusi f I stop, switch off and restart the problem goes away. I'm assuming that once it registers a fault, it stays on even if the bulb starts working
