Egr Pipe Fix And Power Steering Fluid Leak.
Now fixed :) EGR pipe to manifold now blanked off with no adverse affects to running.
Sounds really sweet now its not chuffing like an old tractor from under the bonnet.
and i think it must have been the original o ring on the power steering reservoir,as it broke in 2 it was that brittle !!
  • 6 months later...
Reading this old thread as the "leak" mentioned in the MOT is likely or not from the Power Steering system. It had a new control valve just before I bought it (if that is a power steering part?) Not leaking from front cooling tube or rubber connections.
Don't know if you've ever been amused by the Scotty Kilmer Channel on vutube but came across this which members might be interested in.Could it be the answer?
Will have a better look tomorrow
ps Must get my CS3E running its been in storage now about fifteen years. I serviced the Carbs last year but never got to trying the machine. Always something takes me away from the jobs I start.
