I just cleaned the erg valve on a is220d to get one of the bolts out of the connecting pipe, I removed the Battery, cleaned the valve, replaced everything , but now it won't start? The dash lights up , it goes through the checks, press the button, click , nothing ...? Any ideas?
What did u use to clean valve was it carb cleaner u could have damaged egr using a screw driver too hard,before u put egr back did u check rod was moving freely @ did u connect electrical connection back on best thing is recheck everything seems like fuel is not going through sometimes u miss out small things I dropped small fuel pipe underneath to this day havnt found it best of luck @ do keep us posted
Thanks for the reply, yes I used a screw driver!!! 😖 but would this stop it from even trying to start?
If you have disturbed the Battery then check the earthing point but that would not explain the lights on the dash.
You could try disconnecting the Battery and re-connecting it again ...
U could have damaged rod in it u tube video tells u to b careful when cleaning it can u hear pump when u press start/stop button it's a mystery.did u call aa/rac did u check electrical connection wire hasn't got cut. Or could trying bleeding fuel filter using button inside car good luck keep us posted of the problem
Make sure you have plugged in the EGR connector. I forgot to push it in tight. Car came up with warning lights. plugged in OBD code reader and it reported code for egr not present. So went back and found the connector loose.
Fixed it!!!! Up and running!! I started again removed the erg ect , checked the valve ect, and cleaned the Battery terminals, what ever I did , the big lad fired up, and running fine! Thanks to every one who replied .. Cheers!
