ok ive just bout the half leather half suede seats for my 2001 lexus is200. now the problem is i dont have the wiring under the carpet for the seats as my old set were manual so ive trolled through the net and loads of google searchs will so no avail so im wondering if anyone can help me thanks in advance gavin
Adjustment is easy just needs a positive and negative easiest way is to run wire from Battery to seats with a inline fuse at the Battery . The heated part will need switches and relays as it needs to be wired so they only work when the engine is running
Does anyone have a step by step disgram with some piks and is easy to understand please
  • 1 year later...
Hi guys, would anyone have an advice on this ?
I'm stuck on wireing the leather seats to a non leather wires (2 cables on 2 connectors, vs 1 big (4cables) connector on heated seats I bought)
