the amp is located inside the the rear drivers side wing
to remove you need to go through the boot
remove the plastic panel around the boot lock
remove the panel behind the rear light cluster
you should now see the amp
it is held by 2 nuts plus 2 umbrella type cream gromets which you need to pinch to release the amp
the connectors are straight forward and self explanatory
i actually seperated the rear parking camera gubbins and plugged them back in so that i had a working reverse camera whilst the amp was being repaired.
my car has 120k on it.
my repair was done by SVT services in edinburgh costing £285 inc return postage
hope this helps
