Hi all
the boot has become detached from its surround in the transmission tunnel and just floats around when I change gear, there does not seem to be any thing to fix it to. does anyone have any ideas?
Theoretically (as I have an auto so don't have a boot!) - unscrew the gear knob, open the snap (on the top of the boot around the gear stick) then pull the front console panel sub-assembly backwards (by gripping the hard part of the rim at the back edge of the boot). This should disengage the 6 clips then you can remove the unit. Maybe then it will be possible to work out why the boot has come off the console panel - maybe it's torn or just come out of some sort of clamp.
Thanks for reply, I will take your advice and look at it next weekend when I get back from work.
Martin.
