Blower Hot One Side
Hi all
As title says when I put blower on heats up ice I thought, girlfriend sat in passenger seat says vents on her side ( passenger ) are blowing cold that's one in middle and oneby door now vent on drives side in middle is blowing hot anyone else had this also any help on a fix many thanks Darren
It's absolutely nothing to do with the A/C on an IS200 or IS300.
It's very very common. It's the heater matrix or trapped air in the cooling system. Sometimes flushing the heater matrix works, sometimes burping the cooling system of air works, sometimes you need to do both, sometimes you need a new heater matrix
If it is heater matrix hope it's not hidden. Right behind dashli,e in 306 I did, complete dash had to come out don't want to do that again will try to burp out air bubble if it this and see from there
