Ignition ... Key Issues
Cdubz
Hi personally I would say no(although I stand to be corrected),think you would have change the door,boot and ecu with a matching set(all from the same car including keys preferably set of two) as well.Not sure the ecu and immobiliser will recognise the new key either,so chances are your engine would turn over but car won't start.Furthermore it for any reason you needed to open the car door manually your ignition key wouldn't be able to this as it's off a different lock.hope this helps.
