No idea how good or bad the car is but on the basis that it's everything you are looking for then It's Christmas time also the end of the month so you couldn't pick a better time to test the Stealer....offer £6k and see if they bite :whistling: ..........good luck!!
The screens mounted in the back of the headrests suggest that this is a SE-L model, and not a SE... Unless these are after market.
A petrol SE-L will have air suspension, as opposed to the traditional set up found in the hybrid RX400h.
I would suggest that you search this forum for information about the air suspension and what to look for in a second hand car, as it is known to be (occasionally) troublesome and (always) expensive to fix.
Good luck.
