righto, it's on, but needs some final tweeking to be finished i think!
I haven't fitted the sensor in the pipe yet, partly coz it's dark out there, and also coz i don't have the bits yet, and i also haven' fitted the breather pipe shown in th picture attachment yet, because i have not got a clue where it's sposed to go!
Any ideas guys?
Stu
pics a bit thin bud, if thats all you can see, no wonder your struggling :D
sorry matt, i had my balaclava on, no wonder i was getting confused! :P :P :P
Have a lok now m8, changed the attacment
Stu
the breather pipe should go into the induction pipe....or near the filter, either way into the induction at some point
the only holes in the pipe are at the ends (obviously!),and a small one near the atachment point to the lump that only big enough for the sensor.
does that mean that i'm gonna have to cut a hole in the pipe somewhere?
im hereeee,,****** thoiugjh but h ere none the less..
err yes all the holes shiould alredy bethere,
well, there's only the one hole in the pipe, and this is it! (see attachment)
it isn't big enough for the breather pipe, but sems ok for the sensor.
I'm about to give TDI a ring bout it. Let you know how it goes!
Stu
Has anyone else had this kit put on their car?
If so, do you have any pics of where pipes etc are supposed to go?
Can the breather pipe go to a small external type filter rather than back into the intake pipe ?
I'm gonna ring mark at TDI tomorrow, and will hopefully be able to put some kind of fitting post up when it's done correctly!
Stu
