Hi, can anyone help plz? I'm after the name, or part number or an idea of where I can get replacement dash bulbs from? I need to replace some blown ones. Please, please help!!
Deano
small ones are t5 or r509t
large are t10 or 501....(same bulb).
eBay is your best bet.....led/smd will last longer...
Presume this is the same for Altezza?
Thinking of changing all mine from orange to have the miles/trip and the temp/clock LCD ones white and all the rest red.
How many of each type are there please? How easy is it to get to the back of the speedometer binicle to change those ones?
Cheers
Yep same for Altezza, 3 large and 2 small.
To remove clocks, there are 2 on column shroud behind steering wheel and one underneath. Then remove the 2 at bottom of clock surround and two at top.
Once removed you will see 3 gold screws holding cluster in, remove these and pull clocks forward and unclip both mutiplugs (might only be one on Altezza).
There's a good tutorial here on this. Just replaced some bulbs myself today. Pretty easy to do.
http://my.is/forums/f221/how-change-your-main-gauge-cluster-ignition-ring-lights-leds-pics-359216
Does anyone know if the dimmer switch for the interior lighting should be illuminated itself? Quite a few of my bulbs have gone recently but couldn't see any light bulb inside the unit when I pulled the plastic shroud off?
Cheers for any help!
Chris.
Dimmer switch for dash lights is not illuminated im afraid.
Brilliant :) Thanks guys!
Does the miles/trip display have a separate bulb just for that "screen"? And if so, which of the sizes is that one please? Was hoping so, in order to do that white and all the other "clocks" red.
mileage is illuminated by one of the bulbs you are replacing.. no more needed fella,
Bugger! Thats what I thought so it wont be easy to get the mileage bit to display a different colour to the dials without modifying the cluster to take a separate bulb and sheild it off somehow! :(
im looking to change my climate control bulbs and i can find a type a bulb all im finding on eBay are t3 t4 t5 so im wondering which two types i need to change to the colour of my choice sorry for being a pain but i really cant find a type a or type b bulb any where just these neo wedge that are t3 t4 t5 hope someone can help
