Hi Guys
When i switch audio to CD player it stays there for about one minute and then reverts back to the sat nav screen....is that normal. Can you keep the screen on a particular mode (Cd/Radio etc)?
Also are there wireless headphones you recommend i get as they were not in the car when i purchased it.
Thanks all.
Bob,
Don't take this the wrong way........but, if you got an Owner's Manual with the car, you'll find most of the answers in there. :)
As far as wireless headphones are concerned, do you mean for you to wear while driving?
Page 202 of your owner's manual explains it all.
Look up "Setting Automatic Transition"
If this is set to ON the screen will revert to the previous one ( in your case Sat Nav) within 20 seconds if no input is given by touching the screen.
To remove this feature turn the feature to off following the instruction in the link below and the same screen will then stay on until changed manually.
http://drivers.lexus.com/t3Portal/document/om/OM50738U/pdf/om07sour/2007om/frame/07ls460o/sec_03_01.pdf
