Tein Na Kit
SteveAudioX
Hi ya...
I got my Tein NA kit today.. Can't wait to fit them, after the excellent results from my TTE anti-roll bar kit.
I did notice some things I'd like your thoughts on...
The first on is that the FRONT Shock seems to have 4 height adjustment, but they look very close together, i.e 7mm apart.
Secondly the REAR seems to have 3 height adjustments?
I also noticed that the HEIGHT adjustments is not something i have seen before on a coilover kit... does this system look safe enough, looks like the suspension will drop under extreem load or serious bump, as it has no locking, just a ring retainer.. unless it's been proven and tested of course. :)
I did notice however that the damping control has the 16 clicks when this TOP SCREW
is turned .
The SPRINGS are of Medium.. so I hope this will be near the same ride quality as the factory ones.. not too hard..
What are your thoughts?
If you leave the height adjustment where it is set out of the box, the ride height should drop 40mm front, 29mm rear. The method that is used for height adjustment on the TEIN NA is normal at this end of the market and is perfectly safe (Koni use it as well).
