Can anyone please advise on how to remove the panel surrounding the ignition switch on my 99 ls 400? It must just clip on, but I don't want to use too much force
Hugh, I've had this panel off and it comes away fairly easily if you (carefully) prise at the bottom or side edge with a thin knife or screwdriver to start things off. It's held (this is from memory), by 3 push-fit clips; 2 at the top and one at the bottom, if I remember correctly. It's been a while since I removed it. Firstly though, remove the plastic circular 'surround' before prising the panel off. Comes off easy, goes back easy. Hope this helps.
