Sticking Wing Mirrors.
It was my intention of cleaning the innards of the wing mirror assemblies as I have found they have been sticking - they don't tilt downwards all of the time when reversing. I have read a few forums from various sites and there seems to be a known problem with the sensors in the mirrors and some issues with the plastic gearing on the small motors that drive the mirrors as they wear out.
I have found a way of getting round the problem - on mine I need to tilt the mirrors up and down to the max positions then put then back to their normal position and then they work fine when reversing for a few weeks. I do this with the manual controls on the door.
To get round sitting in the car and doing this every time I have done the following ....
with the seats and wheel in their correct position you are used to when driving, use a spare memory function. I use number 2 - adjust the mirrors to the lowest tilt they will go and save the setting under the number 2 memory.
The next time you have the issue, then all you need to do is press the number 2 button (mirrors will tilt down) and then press the button you have set with the usual driving positions and they will adjust to the correct position and operate as normal.
I have got into the habit of every now and them pressing the number 2 memory button before I turn the car off. When I re-start it again the system on mine defaults to the number 1 setting so it sets itself. Sounds a bit of hassle but after doing it for a few months you don't notice you are doing it.
Mine do the exact same thing mate. Bloody annoying. I'm thinking of buying full replacement mirrors!
Both my mirrors are also now kaput. Damned annoying that a luxury marque would have so many faults across their range. My wifes 07 BMW is still perfect.
Anyone know if these are repairable - is it the sensors or the motors that go? Don't want to take them to bits to clean and find nothing wrong
the cogs on the motors, pretty sure they are f-----d.
no easy fix, if at all. I would be inclined to put on 08+ mirrors.
