Motorised Monitor
Hi everyone...
I need your input to where a small flush round black push button should go...
I have chosen the drivers side for easier access.
The purpose of this button will be to open and close the motorised monitor. Although the monitor will open and close via the ignition switch.. This will give the user the facitily to operate it manually.
I may also place an identical button on the other side to operate the 2 angles..(if this feature is needed)
Above is a small picture ... Position A is on the JDM dash tray part
Position B is on the Heater vent panel
Hi everyone...
whichever way you choose steve can i have mine in position (A) please :)
