I posted up here recently about a BCM problem with my GS300. I've found the same car (different year) in a dismantlers with its BCM intact and the part numbers differ only slightly (last digit is 1 on mine and 2 on breakers.)
So I'm wondering, is it compatible with my car? Is the last digit an indicator of a production line date or is it a little more specific. Would it have any adverse effect on my car if I were to install it?
Thoughts please..
BCM (Body Control Module) part number 89211-30020?
All parts from models built between 01/2005 to 08/2007 should be compatible.
One of my Celsiors has a UK spec engine ECU fitted JDM ends in 50 and UK in 60 but it works.
Ok, turns out I was wrong again about the location of the BCM. It is in fact behind the glovebox and not the steering column as previously posted by me.
Anyways, I installed the brand new second hand BCM and straight away my wipers worked. The part numbers weren't an exact match but the newer one worked nonetheless.
Thanks again for the info, Steve.
