Comms Expert Needed
Scorpion
Yep correct Matt
not used this particular combo - but having had two BT headsets for my T68 - the SOP is
1 - choose the "Pair Device" option from your phones menu
2 - Hold down the "button" on the headset for around ten seconds, until it makes sme kind of tone - this is effectively putting the headset into pairing mode.
3 - when the phone picks up the device, answer YES to "Add to Paired Devices" question - passkey will be in the destructions - normally something like 0000
that should be pretty much it - which bit are you having problems with?
Hey...Hey Success,
Trotted off to the local C/W,told them my troubles i had with the phone and.........voila !!!
all is working fine now :P :P
The problem was it was a faulty one that had slipped through Q.control so gave me a new one,
set it up and all is hunky dory :lol:
Thanks for all those that helped me(except Bazza,coz he thought i did'nt read the manual) :shutit:
B) B)
Dont set up in the shop,you'll be there ages as it picks up all B/tooth devices :lol::lol:
Hey...Hey Success,
B) B)
i presumed that you wouldnt read the manual,
you being a man :lol:
typical man would spend three hours trying to make something work before looking in the manual, :whistling:
