Cruise Control
KDS
Just for info - if you accidentally like I did leave the drive in B - you can't engage cruise - logical but a bit perturbing until you realise your error
Sent from my iPhone using Lexus OC
yes i have done that also you try to turn on cc and it wont go on but you still try to get the cc to work until you look to the other side and see you are in the braking mode / re gen mode , it would be good if when going into cc the braking mode would automatically go back to d
don't believe that B is for re-gen. That story normally comes from ignorant sales people. Using it will potentially increase your fuel consumption.
yes it was sales staff that told me that in "b" it gives you the equivalent of engine braking when going down hills and also in that mode it helps charge the batteries up quicker
the first part is right and is what it should be used for.
It doesn't charge up the batteries quicker than just applying the same amount of braking force manually and only a certain amount of energy can be obtained from the regen braking system, most of that extra resistance when in B mode is generated by turning over the petrol engine. Using B on anything other that steep hills typically increases fuel consumption because you get very little coasting, you are on the power longer coming up to a junction rather than coming off the throttle early and gently braking.
