Need New Alloys -- Please Advise
Bingo123
i own an IS 250 Argento ICE Silver and i am not very happy with the alloys.
they do look a bit boring to me and on top of that the brake dust makes the front ones black so quickly.
So i was thinking of going for black or gunmetal alloys but i dont wanna try Paint etc
Are there any replacement alloys available from Lexus itself in 17" as i dont want to upsize as well.
Your thoughts and suggestions most welcome..
thanks
Not really much help - Just I find cleaning these alloys quite easy compared to some...
So if looking at replacements - Check to see how easy they would be to clean!
I've seen some that look like they'd take an hour to clean properly...
i dont want this powder coating stuff done as i am a bit sceptical that after few rounds of washing/cleaning, they will start fading out.
2 more things :
while i was searching to buy my 250, i came across one with so called Titanium alloys and it looked really cool. Where can i get hold of them. i am pretty sure that those were 17 inchers.
secondly, there are few 18 inchers available in the accessories pamphlet by Lexus, Can i go for them ? Will they fit perfectly ? Has IS250 came with 18 inchers ever ?
IS 250 definitely came with 18" alloys but going by forum threads here, prone to cracking.
Also harder ride.
If you have 245's on the front - they do rub the wheel arches.
So stick with the 225's for front, 245's at rear (or both 225's)
yeah of course, 18 inchers will make the ride worse and specially our pot holed roads in london.
i have 225 in front and 245 in rear.
Can you confirm what exact size Is250 came with 18 inchers ?
look at the following link, here the finish seems gunmetal on alloys
Where can i buy these or get this done at least ???
http://www.ebay.co.uk/itm/Lexus-IS-220d-2-2TD-SE-Silver-2006-58-000-Miles-17-Grey-Alloy-Leather-Seats-/201121246223?pt=Automobiles_UK&hash=item2ed3c2ac0f
There must be many places in London that will refurb your wheels to any chosen colour. I thought you wanted a different set of wheels altogether.
I have 18's on my car, 225 on front and 255 on the rear.
These are what I have
ok now, how can we find the part number ????
just by calling the dealer ?
also, will it be a straight fit on a 07 SE ?
also, will it void my warranty/Insurance etc in some way ?
please advise.
I'm sure the dealer will either know the wheel or can access the old on-line brochures themselves. Then they can see the pattern with their own eyes.
Ask them on the other points.
Had mine powder coated in gunmetal grey. They look great. Considering they were outrageously corroded before the refurb, the finish is very good - not perfect, but only noticable from a few inches away.
They look absolutely in mint condition after a few months. No evidence of fading, peeling, scratching or corrosion.
I usually wash by hand but the wheels have been washed almost every week if the weather is warm enough. I've pressure washed them a few times, but from a bit of a distance - keep the nozzle about 1 foot away from the wheel.
The recommendation from the refurbers was not to pressure wash them, but the powder coat is so much tougher than the paint/lacquer that was originally on them, that I can't believe that it would be significantly damaged unless you literally had the pressure wash nozzle literally touching the wheel or were using a hot water pressure wash. The thing that you do need to be careful with is industrial wheel cleaner chemicals - especially ones which use hydrofluoric acid - as that stuff will eat the powdercoat (it's amazing at dissolving brake dust, which is why it's used - but it will also eat pretty much anything else so you can't buy this sort of stuff of the shelf - it's only used at "professional" car washes).
The trick with a refurb is that you have to get it done properly - the previous owner had had a cheap refurb done - basically just spray painted over the old peeling and corroded lacquer - so the paint just peeled off after a year or so. If you're getting it done properly, you need to find a place that will chemical strip and bead blast the wheels.
