a sealent that repels water....and drys hard, RTV means "room temperature vulcanizing"
  • Replies 688
  • Created
  • Last Reply
Top Posters In This Topic
leading on from that? is this product intended for the use you have applied, if yes who makes it?
nope its not intended for filling rubber damping bushes :D the one i have used is made by Loctite
You rascal.........
note to self (steel idea from Mat)
Oh that's a good idea Mat....... i was going to suggest something similar.....anytime soooon :shifty:
so there i was............working nights again.....(or supposed to be)
Thought i would have a go at replacing the rubber diff mounts for the aluminum solid diff mounts
Old Diff mounts in subframe
Old diff mounts..........out of subframe
new diff mounts, in nice painted subframe
next i had a go at setting up the V-mount configuration for the radiator and intercooler, this took bloomin ages!!
Front, bonnet down
front, bonnet up
Top view
Rear view
Side view
now im happy with the location i need to modify the radiator filler, and inlet / outlet pipes
and start to make up the brackets to hold it all into place, the intercooler inlet/outlets need changing aswell........time to crank up the TIG machine
Posted (edited)
just had a delivery by Fedex......
my pipes to make my turbo manifold
i think i may have ordered 2 much, however better to have too nuch than not enough
The custom collector...inside
and outside
i have the head flange, now i have the pipes and collector, i ven have the turbo flange........soon i can start making the manifold :)
Edited by Monster-Mat
not much has happened the last week......
today ive boxed in the lower rear arms, this will make them significantly stronger
and a nice lick of paint
Posted (edited)
hmmm, good job Thom has just gonr home.......
well today some bits were done to both drift lex....
The inside
Both lex in workshop
The fuel system, awaiting fuel lines
Fibreglass bonnet (3.1 kilo)
Spoilerless bootlid, New rear bumper skirt
Both lex again....
Swap shop.......changing of a few body panels around
Question for you Mat if you don't mind?
During the construction of the 'driffty' i have watched passionately at the design of the suspension.... one area that puzzles 'me' solely due to a lack of understanding is 'why' doe's the 'driffty' have adjustable rear tie rods?
Not the Camber adjusters
Not the toe adjusters
but there are Longitudinal adjustable tie rods.... why is this?
The set-up is similar to the MR2 rear adjusters...... my 'uneducated' interpretation is that the adjusters align the drive train/Axel... is this the reason?
pretty much so tony, however, im hoping shortly to have a fully adjustable front and rear suspension, fully adjustable in every needed plane, possible!
this is the stuff im hopefully trying to source from japan...if the sponser deal goes through!
Front Suspension
consisting off..
Front lower pillow ball arm
front lower arm
front upper arm
Rear Suspension set up
consisting of....
rear lower arm
Rear upper arm
rear traction rods
rear toe control rods
Front Suspension
consisting off..
front lower arm
front upper arm
consisting of....
rear lower arm
Rear upper arm
rear traction rods
You are making me 'dribble'........ are these parts made to order?.... they look absolutely astounding quality!
The 3D geometry will be very interesting with all the adjusters fitted.... 'total control'.... i only hope WIM is ready when you are.
