Ok... i have 6mm on 17s at the mo...
anymore i'd need to spend some wonga right?
yep i have 40mm studs on the front of the drift car, as the SSR wheels catch the calipers, so when i have the SSR's fitted i put 25mm spacers on the front
  • Replies 688
  • Created
  • Last Reply
Top Posters In This Topic
Posted (edited)
well im nearly there with the fuel components....Just waiting on a few unions and the -8 fuel hose.
ive built up the fuel cell completely now, with installed fuel level sender unit
and i mounted all the major components on an Aluminum tray, so it can be removed as a whole unit...
and an overall shot....
when the hose turns up i will make up all the fuel lines, fit the primary filters
Removing the windscreen and rear glass tommorow
Edited by Monster-Mat
Complying with racing requirements is one thing..... making it look so beautiful is another, Tiss a work of art Mat!
I know i will be branded 'Thicky McThick' for asking this but, what type, and octane is the fuel you will use!
Anyone that says 'Diesel' will be ignored :D
Posted (edited)
will be running 98 ron fuel or higher, but it will be mapped on 98
ive not.......actually gone out my way to make it look nice......the blues and reds are just the anodised colours the aluminium parts come in, the sheet aluminum is shiney, cos its new :D
damn you have rolled those arches out a little!!!
I looked in the frost catalogue and a full arch rolling kit is £250, think i might invest in one as thats almost what they charge you in a garage!!
well this weekend i was mostly getting dirty and narked off again.....
rollcage removed fully.........what a pain in the ***** that was, i obviously did to much of a good job, getting it in
next up was to remove the 13" thick rubber sound insulation from the rear wheel arches.....what a pain in the *****, the only way to do it in the end, was set fire to it
after a few hours, was time for the undercoat
also painted all the boot area......
fitted the fuel pump tray.....
removed the rear subframe, in preperation for fitting the KAAZ 2 way differential, Boris Factory gear reduction pinion and the El Sport differential mounts, plust some structural work on the subframe
fabricated the mounts, and mounted the Tilton pedal box......what a pain in the *****
as a result of the pedal box being further away from the bulkhead.........the seat needed moving backwards, this has some possitive side effects.....however new seat mounts needed making up....
the 2 pedals are clutch, and brakes, i havnt fitted the accelerator yet, as its not hydraulic
looking good mat :whistling:
I dont know if you know or not but, D1 is on Sky at the weekends at 8.30am :winky:
i didnt know Marcus, cheers for the heads up....... :)
Oh giddy up.......mr parcelforce has just arrived..only been waiting for this parcel for 13 weeks
Hmm, seems kinda light, and small for what ive ordered......and i didnt order anything from RAYS
ahha.....the rest is coming in a second shipment
however here we have.....
The aluminium Differential mounts
And the BORIS FACTORY final drive pinion gear set (5.125)
HKS Oil Cooler set
still awaiting to arrive.....
TRD engine and gearbox mounts
TRUST high capacity baffled racing oil sump
OGURA clutch and Ultralight flywheel (ORC)
Wow this is turning into a right weapon Matt
wicked stuff
never seen a project like this before
thanks for sharing it with us
mechanical mods a still new to me and it's great to see pics of the parts
and the drift machine being built from the bare shell all the way up
what are you doing with your old inlet plenum when you make your new 1 :shifty:
or will there be a bit of modding to the old one
wicked stuff
yep cutting and modding the original
More goodies arrived today......
and a very crucial part,...................
The fuel pressure Guage
did some more Dirty work, Today i started the strip down of the Subframe
and in bits
and stripped the old paint out the engine bay, and gave it a new lick of paint
well spent the day doing some work on the dash, after Trimming it down, and removing the parts of the vent system that wont be required, i started having a look at mounting some of the gauges..., i wanted to use the original area for a more factory look, so in the binacle ive mounted the Tachometer, fuel pressure gauge and the fuel level gauge, i still have to mount.....somewhere.....Boost, oil temp, oil pressure, Volt meter, water temp, and the lcd display for EGT.......
here are the 3 binacle mounted Gauges
also made up the bracket, and mounted the oil pots...for the brakes and clutch
and test fitted the HKS oil cooler, some modification was and still is needed, i want to make more sturdy mounting points, im also thinking of mounting a small fan on the cooler for when the car is static after a hard run
forgive me for being stupid, but will that final drive kit increase or decrease the speed of the car. i am assuming that it will decrease it but give faster acceleration
correcta mundo christopher
so last night i was working.......or supposed to be, well i was "in work" so that counts
did a bit more on the instruments.....
blacked out the aluminium panel and fitted the boost guage (fitted in the drivers vent)
Fitted the shift light (top of the console) and the adjuster knob for the brake bias (Red Knob)
dash is trimmed down in preperation for the new centre console
Rather than paying 50 million to have TRD bushes fitted i have used an old "racers" trick, of filling the bushes with RTV sealent
Just starting to fill one of the bushes.
Same bush filled
and the subframe, with all bushes filled with RTV
the black rtv is super hard and a real pain in the ar$$ to remove once it is set - but that wont bother u much!
Risking the opportunity to look a total 'plank'...... RTV? what is the complete name and normal use?
