now , the car must be sub 1000kg
OMG :ph34r:
"Gimme Traction Baby" B)
But I think traction is not important for drifting, it shouldn't be a dragcar. :winky:
ah, but i have to put stuff back in........
fuel cell, still yet to remove the OEM fuel tank, oem tank weighs at least 15-20 kg
erm....electronics...(only a couple of KGs)
erm....the 6 point roll cage is being removed and a 20 point weld in cage fitted
erm........the engine, after removal of the 1g, plus i need to fit the aluminum radiator, fit the intercooler, turbo manifold, turbo and all that sort of gubbins, so i think it will weigh back in at around....1100, or hopefully 1050
Great Job Mat(e)!
Now you have two cars I'd like to get a ride once with.
:D
:crying:
:tomato:
In my opinion the IS is the better DriftCar than a DragCar.
  • Replies 688
  • Created
  • Last Reply
Top Posters In This Topic
OMG :ph34r:
Great Job Mat(e)!
:D
:crying:
:tomato:
The weight in the rear is the key as you can see..... :crybaby: (click)
ouch
looks like something broke
steering or suspension
even with correction to the right, the car veered heavy left, and the front wheels were pointing left :crying:
Posted (edited)
Today my HKS filter......dont like the green
and my 2 HKS guages turned up
oil temp and oil pressure.........
still need to get
boost, fuel pressure, water temperature......
ive already got a Mines LCD EGT guage
and ive just ordered this......from japan, me thinks i may need it
Engine Torque Damper
Edited by Monster-Mat
ouch
Watch again and you will notice that he turns leftside when shifting in 3rd gear.... :ph34r:
My think says: "MUCH POWAAAAA!!!" B)
Can't wait to see the driftcar....
Maybe Mat can do some drifts on the sand track in the JAE area... :lol:
Mat,
i've seen alot of guys in japan running engine dampers... are they really worth it?
My engine rocks quite a bit when its being rev'd..
Just wondered what your thoughts were on it.
Mat,
Am, to be honest this was the first id seen for the Altezza, so had to get it.
i think it will be "usefull" rather than worth it, as with all the sideways action it would put alot of strain on the TRD engine mounts........
Where did you get the gauges Matt? Looking for some of these myself.
i got them of a friend of a friend of a friend of a friend of a friend of a friend of a friend of a friend of a friend of a friend for £40 each brand new, in Japan
That's a great price!
If you are thinking of bringing in anything else this way can I bung you some wedge to buy me some - EGT, boost & oil temp?
£40 :o
can i have a boost gauge at that price? :D
ok.lets not turn this into a "i want one aswell........."
when i do my next order for stuff oriental...i will let you all know........maybe
Mat can you tell me what this thing does??
(technician explanation please :P )
its an Engine Torque Damper, Adding power and torque beyond your vehicle's OEM specifications leads to increased engine twist and movement, especially under extreme driving conditions. This can result in reduced power transfer, and or missed shifts from driveline Displacement. Silkroad engine torque dampers absorbs and minimizes this movement of the driveline, thereby reducing the Possibility of costly engine damage from accidental misshifting.. Silkroads ETDs are also effective in absorbing engine movement. As a result, you can enjoy more power to the wheels, while also minimizing stress to the engine and the car body.
And where is this mounted to prevent driveshaft moving and so on??
Gearbox? Engine? :unsure::tomato:
Posted (edited)
engine, cant you see the bit that bolts to the suspension tower......as in where a strut brace would fit
Am, you got a pic of one of these fitted
I have thousands of Altezza pics.... think i could start up a worldwide Altezza Gallery :P
Running a STB will be fun
i wont need a tower bar, the roll cage that is being welded in goes through the bulkhead and is welded onto the suspension struts, front and rear.
basically a 20 point cage
You shouldn't roll across the track, you should drift. :P
hmm me can see some modification required to the damper mount brackets for my top mount turbo to fit ok....
Looks it. Unless you can strategically bend that boost pipe off the turbo... looks tight in any case!
Posted (edited)
what boost pipe...thers no turbo in that pic
the problem will be the intercooler pipes.................i,ll sort it :)
