Aircon Temperature
Think mine needs a re-gas but checking how others find theirs first. I am used to it being ice cold in other cars but in my isf it takes a good 5 minutes to get cold ish.
Am I alone?
Stu
Sounds like an internal flap is stuck so you are only getting cold air directed to one side, or the drivers side temp sensor might be dodgy.
Not at all. £90. Inspection of aircon unit, dye in system to look for leakes. System vacuumed and re-filled.
VERY cold straight away now :) as I would expect.
Thanks Stuart....mine is cold but a slight smell every now and then which means it may need regassing.
Oh on. Not pricey at all. It was toyota though. They are 5 mins from me while lexus is 45 so I go there for small jobs.
Glad you got it sorted Stu. :)
If you get that kind of musky smell when you turn off the A/C, does that suggest you need a re-gas then? Only ask as mine is doing that a lot at the moment! :(
May have to get mine done if that's the case.
Think mine could do with a re-gas and deodorising soon. :(
May see if my local Toyota dealer can do it. If not, may try Lexus Canterbury.
Wonder how long the offer Malc got is running? Will do some digging. :)
