does anyone have the same squeeks as me, my most annoying one is the passengers seat when empty. it squeaks and squeaks until i lean on the drivers side of it, then it goes but as you can imagine this is not a solution. the second squeak comes from the head lining, they are totaly driving me mad, and i dont fancy paying lexus bromley £75 and hour to find nothing :winky:
My passenger seat had a similar noise, tracked it down to the bar that you pull to move the seat, it vibrates and sqeaks when you are travelling. Ended up puting a little WD40 where it pivots and it stopped :D
Geoff in Oz
Best thing is to go for a drive witn a M8.
Heave him loose in the back seat or something applying pressure to any points that you may think is squeeking..
then you know the places.... just LUB or try some density foam sheets.... (as for the in-between of the headliner) .. :)
:P :P We could all sit in at Blue Water meet :P :P
cheers guys, i will be having a go round my seats with a can of wd40, lol.
Well i hope i can get to the bottom of this before i have the first single seater is200 out there, lol.
i`ll try the bar under the pass seat,its been ****** me off too,thanks lads :)
