I have had my door lining off today.. To test what i thought was a blown speaker.. could not see anything so took out speaker from passenger side still did not work tested the one i thought was blown in passenger side and it worked ok .. So then pulled out stereo an checked wires there .all looked o.k so then into the boot and check wires from amp.. again all seemed o.k.. tested for power at the last connector nearest the speaker and showed a live current.. I am confussed as to why there is no sound... When i first got the car it would come and go intermitently like there was a loose wire when turning a corner..
help I am at a loss to what the problem is..
jac
  • 2 months later...
