Is F Front Disc Dimensions
Afternoon all,
First of all apologies if this is in the wrong section, could only find LS F general section, and I know it can be a pain for a first poster to post in the wrong section when it's obvious else where.
I've come from the The 350z-Uk forum to you guys for some help.
Long story short, the wheels I've ordered don't clear the front Brembo's. I'm the 1st person in the UK to test them, and we checked everything in terms of fitment, it was fine for all the people in the states running them until we realised the people in the states don't get the brembo package as stock.
Anyway, wheels wont go on without a 20mm spacer, which results in wheel stick way to far out of the arch.
What I'm after is a Brake Disc with a larger Offset/Height (I.e. I'm pushing the disc back further, to allow the clearance I need for the wheel and Brembo)
I've done all the calculations, had brackets made up for all this to work.
Current Disc Dimension is
Diameter: 324mm
Height: 49mm
Thickness: 30mm
PCD: 114.3
What I need is a disc with a larger height. Diameter can be larger, and thickness needs to stay the same, give or take 1mm
After doing lots of research, trying to find some sources, I've found a couple, but I did come across a set that say they are for a Lexus IS F -
http://rpmware.com/catalog/item/580066
Was just wondering and hoping if someone could shed some light on your stock front disc setup, and if you know of any upgraded discs for you cars dimensions.
All help would be extremely appreciated as I'm running out of places, other than having discs custom made up.
Thank you all for reading this :)
Just a random FYI about me,
If I was offered a R35 GTR or a LFA - LFA all day long, big favorite car of mine :)
Hi guys,
Appreciate the replies :)
@Peter aye thats a big help ta!
@NWB - Problem with a lot of suppliers is, they all only go for stock and what the computer says will fit the car, that's the issue when going custom, computers don't think outside the box.
But not to worry guys, out of the 15 suppliers I've contacted, one finally came through with what I need :)
Again thank you for your help!
