Not a make I've heard of myself, offset basically means how far the wheels either stick out or tuck under the arches but also how close they are to the suspension at the back of the wheel.
I don't understand why they quote 2 figures as offset is fixed.
Lexus offset is quoted as between 35-42 so anything within these values will fit without modifications.
You may also have to replace the wheel nuts as most aftermarket wheels use taper nuts not used on standard Lexus wheels.
Thanks for that. I think my main concern is that they miss the callipers, knowing how little clearance there is.
