Can I Re-build It............
im gonna use it for track days
the way i see it, the is200 as std isnt that slow for a 4 door saloon.........
now, strip out all the weight, remove anything thats not needed
stereo,amp and hifi components
carpets
seats(factory)
headlining,sunroof
aircon
engine covers
bootliners
underseal
under car panels
change rear door and passenger door glass for plexiglass
remove door panels
remove window motors
basically strip off everything.............
you will make a considerable weight saving........now, do some weight transfer
Battery to the boot....and whatever else i can relocate there(ecu)
i think it will be a fairly demon car on the track....and if i can blag another supercharger......... :winky:
blue one has
drivers door, passenger rear and rear quarter panel damage, plus light damage to the rear subframe, and boot floor
its actually easier to repair the aztec fire one, as i need full panels and not parts of panels as is required on the blue on
we will see
