Flywheel Bolt Length, Is200 Sportcross, 07, 2002
Gentlemen,
i've purchased a lightweight flywheel and intend to fit it asap. I intend to have all the bits for the job before i start of course, but i have one small problem: Flywheel bolt lengths/dimensions.
The new flywheel has a flange thickness of 17.5mm. What I need to know is the original bolt length and/or the thickness of the original flywheel flange to determine my "new" bolt length.
I understand that there's a bolt length difference between pre and post 07-2002 models too.
Does anybody here on the forum have access to this sort of info? (Bolt length pre and post 07,2002).
(I can't lay the car up as i need it for work, otherwise i'd crack it all open and then source the parts...)
Heeeeelp!!!!!
Thanks in advance and greetings from sunny Holland
(btw, my car is from 19,08,2002 and not as in the topic title, 7, 2002. Ican't seem to be able to change that.)
