Dare I say the same as you had before? If you had the one with the CD slot at the bottom I would try and change up to the variant with the CD slot at the top ( they were less prone to jamming). On the front of the stereo casing there is a number. This is only from memory...but it something like 13906, 13902, 13909 etc. You also need to establish if you have the amp behind the glovebox. This will determine the specifics of the connectors at the rear of the stereo.
Try posting this in the is200 section and I'm sure you'll get more responses from current owners. Sorry can't remember more clearly...it was about 5 years ago that I had my 200 Sport Navigator!!
