Watling Towbars do a towbar for the LS400 - see www.watling-towbars.co.uk
Click on Price Lists on the narrow blue horizontal band, scroll down to Towbars Pricelist - Jan 2013 and click on this. Lexus are on p22. They are not cheap to buy - £264.00!!
I have one fitted to my 1997 LS400. I did not fit it or have it fitted, as it was on the car when I bought it (and it was one of the reasons I bought the car).
Mine is a Mk 3 car, although they will fit the Mk 4. You will see from the Pricelist that the towbar goes up to Jul 98 i.e. the end of R reg cars, so if yours is a R reg car that will be fine.
EU Type Approval for Towbars came in on 1 August 1998 and, although the towbar will fit S reg cars onwards, it is not a Type Approved towbar. As I understand it, it is a legal requirement for vehicles registered after 1 August 1998 to have only a Type Approved towbar fitted and it will be an offence under the Construction & Use Regulations if a non-approved towbar is fitted. It might also affect your insurance.
Hope this helps.
Colin
Thank you for the replies to my query.
In particular thank you to Colin M. Watling appear an excellent company, I would definitely recommend them. I phoned Wednesday afternoon and the towbar was delivered Thursday morning. It is hopefully being fitted next week.
June
I found Watling very helpful too.
Before buying a car with one of their towbars fitted, I contacted them to ask for a fitting diagram showing where the mounting points were, as I was thinking of fitting a towbar to my lpg LS400. They emailed one by return and dealt quickly with a couple of follow up queries I had.
I did not go down this route in the end, as having another LS400 with a towbar already fitted seemed a better option. Why have only one LS400 if the opportunity is there to have two?!!
